Switched out the stock OEM filter to the black market performance fuel filter kit and now hopefully I don’t have to worry about mine catching on fire. This Baldwin filter has the same OEM specs as the motorcraft fuel filter.
Nah, the RCD stroker pump I’m gonna put on is built that if it goes no metal parks will destroy the rest of the fuel system.No plans on an S&S disaster prevention kit going forward?
Cause the OEM ones have been known to crack and there’s been several trucks to catch on fire from it.Same as OEM Motorcraft specs you say. Why is this an "upgrade?"
Not the filter, it’s the system/housing that causes the problem. So I think what he’s saying is you can upgrade the durability of the system, and then use a different filter that has the same specs as factory. So you’re not sacrificing anything but get a more durable product and easier to replace when time.Same as OEM Motorcraft specs you say. Why is this an "upgrade?"
