Front receiver
DMac
Tremor Fanatic
NM
2022 Tremor
Anyone look into a front receiver hitch? I would like to do the winch thing but put one in a cradle so I can pull myself out backwards too.
The only receiver I have found mounts below the bumper so it reduces clearance in the front.
I would love to have one that came out of the bumper in the factory winch location.
Thanks!
Nevermind, I found it.
So, any input on running the wiring front and back for a receiver mounted winch? Is the single battery setup adequate to run a winch?
Thanks!
There are several that bolt on….. you lose zero ground clearance.
I’m going to do the same. Here’s the one that I’ll use.
Anderson SBX 350 connectors and 350 mcm Class K welding cable.
Single battery should work, just be sure to do low duty cycles.
