FORScan Speedo/Tire adjustment size correction for those running 37's - solution for 2021 Tremor
I did with no success on my '22. Couldn't get past both the wrench and CEL on any circumference setting other than stock. So I ordered a speedo calibrator to fix it instead.
Following : I need to do something with my 22 tremor as well w, my 37s but I’m waiting for my new set of 18” wheels to come in .
Works great, would order again
Did you use tire and or Gear values, or did you use GPS and Speedometer values for your RC calibrator?
Messing with mine now.
I tried tire and gear values first and it was still off. Switched to GPS and Speedometer and it dialed in perfectly. I used the “Speedomoter” app in the iOS App Store and made sure decimal point readings were turned on for accuracy.
Do you recall what speeds you picked?
It’s going to vary by vehicle and tire size. Mine was by like 3mph, and when I put in that difference between gps and Speedo, it worked great. You need to get on the highway and write down your numbers, both Speedo and gps Speedo (app). I wrote them down at 60, 65, 70 for more data.
Do you know if they have an Android app? I searched the Play store for Inline Speedometer Calibrator, but it shows only regular speedometer apps.
Not sure... I have since learned to use ForScan. Pretty easy to correct the speedo in there.
I tried Forscan changing the tire circumference, mm value with no luck. The moment I change away from the default of 2689 the truck throws an error code. Even did a PCM relearn, but that did not do anything for me. What have you done to get it to work?
In my experience with my SD and with my Gen 3 Raptor as well, these trucks don't like certain #'s. I went with 2740, I don't recall if I had to do a PCM re-learn or not after that. But 2740 was spot on for my 37" Ridge Grapplers.
I have not tried 2740, but tried a few lower numbers and anything above 2700 did not work.
On my Gen 3 Raptor 2766 worked, can try that one too.
My ‘22 Tremor worked with 2770 (I think after 2 tries!). Gave CEL light, reset, CEL again. Changed back to 2689. Cleared lights. Good. Changed to 2770, relearn PCM and TCM (just out of habit). No CEL. Multiple starts of engine and drove around 5min. No CEL. TPMS is picking up pressures too. All good so far.
Before all that I tried: 2790, 2783 - both gave CEL after clearing.
This is interesting. I’m about to do this via forscan and looks like it will only take specific numbers without throwing a CEL. Maybe I’ll try 2770 for my 37s
Tried 2770 for tire circumference. Throws code even after DTC reset and PCM/TCM relearn…don’t know what to do
Does the Rough Country calibrator correct the MPG values or shifting since it only goes to the speedometer.
I got the 2770 with my 21 working without issue. I guess I’m one of the lucky ones
