Ford Pro Upfit Integration System vs. Upfitter Switches
I just pulled this off the .CA ford site...
But if you actually select the "option" it forces you to add 250a alternator and lariat ultimate...
But if you do it with the XLT its a $200 cad option...
I'm GUESSING its an issue with the Ford programming because it was doing the same thing in the US with the max recline seats. Said available for Lariat ultimate, but wouldnt let you actually select it. My dealer had zero issue adding it to my '23 order though.
Can you get ahold of the Canadian "paper"/PDF ordering guide and see what it says? Because thats the ultimate final answer.
Exactly what you pulled. It says available on Lariat on the website clear as day. I don't have a Canadian order guide, but I expect it will be same as US, optional on LARIAT and included with Lariat Ultimate.
Not sure where I can get a Canadian order guide from...
Update on this... Good and bad news.
I have been periodically checking the Ford Canada build site to see if there would be a change with being able to add upfitter switches to a Lariat without having to buy the expensive and mostly useless to me Lariat Ultimate Pkg.
The good news is that as of this morning you can add upfitter switches to a straight Lariat build for $200 in Canada. I immediately emailed my dealer who has acknowledged and added them to my order.
The bad news is that means my truck hasn't gotten a VIN, and is probably a ways off being built, and I need a truck bad...
At least it will be what I wanted when it finally gets scheduled.
Nov 4 order date, priority 12...
BTW I think the ProFit thing is a Fleet only option from the factory. Otherwise you need to order the module and harness from your local dealer.
Actually when my dealer first converted my '22 order into a '23 they included the pro upfitter system and I had them remove it. Maybe it's a Canada thing, you can add it in the Ford Canada build site.
If your truck is built without the OEM Upfitter Switches, check out this YouTube video which covers the installation steps.
If your truck is built without the OEM Upfitter Switches, check out this YouTube video which convers the installation steps.
Thanks for that. I'll definitely look to doing something like that if the switches aren't there for some reason. But with it added to the order now I'm expecting them.
Not Fleet only. My order for a Platinum Tremor currently has it on there. Ford is saying that they are not scheduling any builds with it until further notice though. It might not actually make it on any 2023s. I might take it off at some point to get the truck built. I don't have any plans for what I might use it for. I am just thinking it might be fun for some customization in the future.
