Fog Lamp Replacement
It looks identical to my OEM light.
ETA: When I mounted mine I had to mount them by securing the bottom torx first in order for the lamps to adjust correctly. No, I don't know why but that was the only way for them to adjust correctly on my truck. YMMV.
yep they’re the same 🫡. Did the factory wiring harness require any modifications?
No. The DD wire that comes with the fog lamps connects the new lamps to the original harness.
My 2024 fog lights are halogen - do you know if these DD fogs would still be plug and play?
The Overview on that page seems to indicate that, but not sure if you or anyone else had further insight.
thanks
Can confirm, these are direct p&p takes about 30 minutes to swap. I moved the bumper brackets to make swapping them easier.
I went with yellow, light coverage is similar to oem LEDs, but gives the color I prefer. Will add more lights in the future. Would love to do something behind the grill.
I just got my delivery from Diode Dynamics. I also ordered the Backlight wiring Tap kit. Glad I did, as the Fog lights have a four pin pin connector, but I have a two pin harness on my XLT. I take it the extra pins on the LED fog lights are for the DRL. Not sure if I want to run those.
I also ordered the additional $20 wiring kit and ended up not needing it. The lights came with a wiring kit that fit and has the DRL wire tap included, though I just kept it unplugged.
When I aimed my lights I was at the lower limit (no more downward adjustment) and it could have gone down a little more to be accurately aligned, but close enough for gov't work.
Doh! @moontraveler1984 you are right.
I had only opened the top half of the packaging to get to the fog lights. At the very bottom of the packaging, under the expanding spray foam, is basically the the same harness.
Appreciate your support, buddy! Shipping tomorrow!
Let's goooooooooooooooooo! I really went back and forth on the color. I'd like the added contrast in fog, but I do use my fogs as running lights too. What pushed me over the edge is how one fog light comes on when you're turning, I think yellow would look weird for that. Probably should just wire them up to an upfitter so I can turn them on and off whenever I want, but then you loose the turn feature.....
You can turn that feature off with Forscan. We recommend it for our single Baja Designs kits that are not always road legal.
Here's the coding you need to change in Forscan, if desired:
2023-ford-super-duty-baja-designs-squadron-fog-light-kit-apollo-off-road-68929.png.webp
for some reason I never dabbled in forscan, I need to. I have the cable already from another project.
