First Oil Change.
The last time I heard the term Break-In oil was back in the 70’s. I recall that the oil was heavier weight with some additional chemicals in it and part of its job was to also help remove the initial metal shavings that were present due to the initial wear.
I was raised on the belief that you should change the oil and filter
That being said, I follow the Service Manual’s recommendations.
I have Ford’s MaintenanceCare Severe Duty Plan on my Tremor (As well as the Ford PremiumCare ESP Coverage) which services it every 5,000 miles. My first service reminder popped up just under the 5K mark and that was also when the DEF tank indicated that it was running low. The Ford Dealer serviced it as required. I figure that way, if anything happens with the engine, it’s under warranty and if they claim something wasn’t properly done to it, it’s on them and not me.
I‘m not planning on having it beyond the warranty coverage so I won’t be experiencing any grief either way with it.
If I was planning on putting 3-500,000 miles on it, I might do things a little differently, but since I’m not, I’m fine with what the manual says and the MaintenanceCare provides.
I can appreciate the members here that look beyond the basic information in an attempt to do the best thing possible for their investments. In my case, anything above what the manual says isn’t necessary.
It could be BS, I can't say. I am just passing on info I was given. It is a personal choice. Since I was a sheetmetal and fiberglass mech on Apache helicopters, I am clueless on engines. So I personally trust someone who works at the plant over Google or You Tube. If I had been a heavy wheel mech instead, I might have a better understanding, but I wasn't. I pray all of our trucks work seamlessly for years to come. I hate seeing anyone struggle with issues on new trucks especially.
Sounds like a pantload to me.... Will do like I always do. Change engine, tranny and diffs at 1k to the appropriate Amsoil fluid.
I do the same. My wife's 2021 Explorer Timberline, the dealer installed my Amsoil fluids (engine, transfer case, front/rear differential) at 250 miles.
Every new vehicle we've owned for the past 30 years, we always switched to Amsoil within a few hundred miles. I've put many miles on our vehicles, never an oil burning issue or engine issue!
He acted like it was a proprietary blend. He didn't name any of the additives.
More than likely has a higher zinc content, which is weird because engine manufacturers haven’t used “brake in” oil for years now high performance engine builders for sure use brake in oil to seat everything
My other .02 worth. I don't know what kind of oil they put in it at the factory. But I believe they will cut as many corners as they can. So I personally don't trust what is in it. I have checked my front and rear diffs and transfer case on the Tremor and other 4x4 trucks and found them to be "low" on gear lube from the factory. So its also a good Idea to check the levels.
The oil filter on both my 6.7 and 7.3 were not the traditional Motorcraft filters. They came from the dealer with a plain white painted filter that said Ford on it. It was extremely tight and the housing was really thin. Seemed like a low grade el cheapo filter. causing me to believe there is more corner cutting for bigger profits.
I am not an engineer or an engine builder. Just a guy who likes his Tremor and wants to keep it running good for as long as I can.
I think your on to something here.
Did my first oil change on my new Tremor yesterday at about 3200 miles. I have the 6.7 Liter Diesel. My last truck was also a Super Duty with the 7.3 Liter Power Stroke. With the new truck the drain plug is located on the side of the oil pan. When I removed the plug, hot oil shot horizontally out of the pan about 18”. Fortunately I had a large bucket so I was able to contain most of it. I liked the old Power Stroke design because the drain plug was on the bottom of the pan. When the oil came out after the plug was removed, it shot straight down instead of on my arm, hand, and whatever else was in the way. This current configuration shoots oil all over the place. Also, my old plug was magnetized. This one isn’t. I like the old configuration on the 7.3 Liter Power Stroke. It was a better design. I replaced the oil drain plug with the Fumoto valve. I hope that will improve my next oil change experience.
At the first change is when I swap to a fumoto even with the Cummins that’s straight down because 3 gallons comes out like a rocket, you say the powerstroke is on the side of the pan might be worth while to have a little 90* fitting on the fumoto pretty sure they make that
Shooting out like a rocket pretty well describes what happened when I removed the drain plug. I bought a short piece of 3/8” i.d. tubing that will fit on the end of the Fumoto ball valve. My plan is to dump the oil into an old 5 gallon gas can by running the other end of the tube into it.
