I picked up a used 2020 with a procharger and noticed my dash has a turbo pressure reading (reads 0). Is there a way to hook up a sending unit to read my boost pressure on the factory readout?
Unfortunately there is not one that I could figure out. I too added it to the instrument cluster, but with a boost pressure reading of 0 to 40 a few pounds of boost wouldn't register, even if you could map it to the manifold pressure. Someone with advanced knowledge of the IPC layout might be able to make those changes, but in looking at LivinitUp's F-150 IPC detailed mapping (a superduty one is not available like that but it's supposedly the similar clusters), there was not an option or way to change that in all of the IPC addresses you can access in Forscan.
What I did was add a P3 guage. Here is the link to the install:
Added a Boost Gauge over the last several days. Went with the P3 Vent Analog Gauge and wired it to the #1 Upfitter Switch. Ran it through the firewall in the existing boot (a big PITA). Took my time and made it look factory/first class.
www.fordtremor.com
You will find that the engine rarely operates in any boost situation (at least with the Whipple). The engine is probably under a low (1 - 3PSI) boost maybe <1% of the time it's in operation. The only time mine gets anywhere in the 4 - 6 range is if I am accelerating towing heavy or accelerating at WOT. The issue with WOT is that it is a short period of time as it accelerates so fast that the governor kicks in at 100.
