- OP 🔹
- #21
Way less hunting with this setup.
Anyone run 605 20inch method wheels? I’ve heard they ride really stiff. Then one experience I’ve heard actually switched out to 18 inch methods.I like that a lot! I’ve been thinking I would wait until I wear these out but I don’t know if I’ll be able to stand it that long... lol wonder if i could go 20’s with a 35 and no running???
Looks great. Did you level it first?
I am running 37x12.50 R 17 on my truck.would 17 inch methods fit?
So that is 18x9 with -12 offset on front and rear? Running 35x12.5x18 Toyo MT? I think that is what I am reading.
That's what I read but want to double check before looking to do a similar look. Do you tow at all with that? We tow a wakeboard boat and want to make sure the tires are hard enough that the sidewall doesn't get mushy when loaded.Correct.
This may be a dumb question but... why do the 18 Methods with 35's fill up the wheel well so much better than the stock Tremor wheels (which are also 18's with 35's)? Is it the width causing it to appear like more wheel/tire maybe?
My one criticism of the Tremor is the wheel/tire size. I feel like 20's with 35's would be the perfect look for my taste.
Yeah, that's probably what I'm seeing. I saw a levelled Lariat with the sport package (which has black 20's on it stock) with 35's on it that looked awesome. It wasn't a Tremor but got me to thinking about wheel and tire options. Thanks.Factory wheels are 18 x 8, pretty narrow. The 18 x 9 with the wider 12.5 Toyo MT definitely adds width to the tires versus the stock setup.
Did you go Platinum again? I am about to order my Tremor and I have a Platinum now. I am thinking of going loaded Lariat instead to lessen the shiney parts. Are you going to keep the stock Tremor wheels or get something else this go around?My current Platinum, Tremor coming in February
37x12.50R22 with 22x10 Black Rhinos
I run 45psi front and rear when not loaded or towingView attachment 11190
