Over all the installation went fine. It takes longer for my to get up and down off the floor, so it took about 10 hours to install.
The handling (with out the Cirrus 820) was much tighter, and will look forward to putting the camper on to see how the airbags help.
There are only few complaints on the airbags installation.
1) You spend all this money and then supply you with crappy self tapping screws that should have been stainless
2) Tapping into the frame should be threaded first then screwed in.
3) Everything should be lose (except the top plates mounted on the bags) then tighten.
4) The uplifter wire codes are wrong in the manual, but I am glad, I was able wring them all out, label them.
5) Don't cut into the fuse box and tap into a fuse, unless you have no other choice.
6) I did not use the Daystar Air Cradle, I was not in the mode of drilling the lower plates to make them fit. So I returned them, I am not racing the Baja with my camper on. But I was honestly very disappointed watching a video on how to make them fit? Maybe Daystar should watch it.
The sway Bar
1) Make sure the vehicle is sitting level
2) I did use the optional extension eye bolts, not sure if the original ones would work?
Anyways excited to get the camper on and test it out.
The sway Bar
