Exterior Water Drip Passenger Footwell?
Rich Pune
Tremor Junkie
3x Tremor of the Month 🏆
Montana USA
F250 Lariat Tremor
I just got home from running some errands and noticed water, or something just like water, dripping near my oil filter. I found where it is coming from. But no clue what it is. Any guesses?
  • IMG_2251.mp4
    2.2 MB
AC condensate drain. Perfectly normal.. Although I recommend doing the TSB to add an elbow and improving the TSB by adding an extension hose. TSB attached at bottom of post.
Yeah, that original design is somewhat questionable. How do people sit there and say yeah let’s go with that?
Engineer: "We need to change this design"
Program Manager: "Will the reduction in warranty spend offset the cost increase?"
Engineer: "No"
Program Manager: "Request Denied"
The TSB has build dates through early 2020. Does this issue still exist in the 2022 models?
Yes.. the design is the same, so do the TSB anyways. Mine's a 22 and it's better to be proactive.
Engineer: "No"
Program Manager: "Request DeniedWhoa
Engineer: "No"
WHOA! WHOA! It usually the engineer that screwed it up and it takes just a little common sense to fix it. 😉
I have the same exact issue as OP. Today i installed suddle/puddle under power boards lighting, next week ill hit up this project. Been on my to do list for a while, first noticed the water near oil filter on my florida trip this winter when ac was running high.
There is no issue with condensate running out onto the ground. Every car/truck does that. The TSB address a potential issue of condensate running back into the cab. Puddle on the ground = good, puddle in the cab = bad.
Common "sense" doesn't apply... It has to pass the test of dollars and "cents" or it won't happen - that is the reality of today's industry.
