Engine fan seems to be stuck on 6.7L
Hate to bust the news to you but not true -- unless of course, my clutch is simply just gone but my diagnoses did not indicate such.
I don’t disagree that there are probably multiple root causes. Fan clutch issues are all over the place. Programming could definitely vary by model year.
All I know is mine behaves differently in the summer and the only improvement I have found (which doesn’t totally eliminate the problem) has been the recirc. I tested it multiple times and it makes a difference in how long it takes for the clutch to unstick in the summer.
Not sure if there’s a PID for fan clutch engagement, but finding a correlation with 100 other parameters is needle in the haystack stuff. Ambient temp would be the obvious one but there must be more going on in that engine brain.
Was your code/issue resolved?
I am still stumped with this fan clutch "issue."
Went out and tested it again, per indications here, fan clutch appears to "fine" - it is behaving as inteded, turning it by hand with engine off.
The darn things hardly ever turns off, however -- unless it is below 50F ambient temp (from what little I can remember). Is there perhaps a sensor of some sort that activates the clutch or this via the PCM?
I have no codes but this is annoying especially during cooler months, no A/C running, 70s outside, just cruising with windows down, but sounds like an 18-wheeler is approaching nearby.
The code according to ford was a glitch and it has not showed up again as I now have 34K miles on the truck. My fan clutch definitely did not sound normal. Sometimes I was unsure at higher speeds but at 40 or less it was pretty evident. I would take it in and have them look at it if you are still covered with your warranty.
No warranty.
I am at 95K
It was known issue for some of the 23-24 Tremors or 6.7HO. I would think the dealer can at least confirm the issue and then you can resolve it per your choice. I don’t know if it can cause other issues other than maybe less mpg due to the friction it may be causing when it is loud. When I took mine in they knew immediately and scheduled me right away.
I will consider it.
I appreciate the suggestion.
