Engine Block Heater
ffsmith20
Tremor Fanatic
Punxsutawney, Pa
First Responder
Volunteer Firefighter (Department Chief)
2022 F250 6.7L
2017 Ford Fusion
New to a 6.7L, gonna be -25 overnight how long can ya leave engine block heater plugged in for ?
As long as you want. Most effective if plugged in 3hrs before the truck is needed. Any more than that just uses more electricity, but doesn’t hurt anything.
When I still had to go to work I used a heavy duty timer to have my heater come on about 4 hrs before I had to leave. They're 1000 watts so they do draw a bit of juice
All the time. Yeah it is warm after a few hours so you don't have to, but I constantly have to go places on short notice so IO'm not messing around with timers.
we just spent a week at -32c (-25.6f) and if takes alot longer than 4hr to warm up the engine when plugged in.. i left plugged in 100% of the time and it started and idled with zero bad noises. (showed slight temps on dash)
now in the last 24hr its getting warmer here now -15c ( +5f ).. i left it unplugged last nite and just plugged in @ 6am.. when i left home at 10am it didn't warm long enough and it had valve chatter for ~5sec w. no temp registered on the dahs
