Pretty slick truck. Looked at it in Indy a few weeks ago. They have the stats, 2 pages worth of real use data, It was impressive.Not sure how I feel about this, extremely skeptical I must say, want to see real world reports after extended fire ground operations by the crews
It’s still got diesel for backup in case of battery depletion. Don’t remember exactly what the timeframe was but it used 2.11 gallons of diesel and ran close to 300 calls. The diesel was used on 2 extended calls in order to get back to the station.Just wait until the first time damage occurs when the batteries run down during an extended fire!! Going to be some interesting lawsuits over this one.
My God what a waste of money. Kali is something else. They still buy power from Texas and they do not have enough power generation nor oil refining to even support itself! If it were up to me I would let Kali fry or freeze whatever the season.It’s still got diesel for backup in case of battery depletion. Don’t remember exactly what the timeframe was but it used 2.11 gallons of diesel and ran close to 300 calls. The diesel was used on 2 extended calls in order to get back to the station.
You guys realize that back when everyone rode horses they said the same nonsense about horseless vehicles too, right?
The truck itself has a diesel range extender on-board. So if the grid is down, it essentially turns into a diesel truck. If it has diesel, it can continue to run indefinitely.What happens when Calif rolling blackouts happen, diesel generators at the fire stations?
So blackouts are not a concern.
The fire stations almost certainly have diesel backup generators already (like most emergency facilities). They may or may not be setup to power the charger for the truck. I could see that going either way. But that doesn’t impact whether the truck can continue to work in a blackout since, as noted above, the truck is self-sufficient.
I encourage you to watch the first minute of the video. It quickly summarizes how the electric works.How long is the truck self sufficient before it needs refueling?
They didn’t explicitly state this, but there’s two factors here:Can you run the onboard generator inside unattended while the crew sleeps recharging empty batteries
How many gallons is the on board diesel tank?
They don’t answer these questions directly. For battery kind I’m sure it’s using similar tech to all electric cars today. Something lithium based.What kind of battery & what’s the lifespan
When you say “engine” in this context, are you referring specifically to the diesel range extender (Diesel engine) or the fire engine as a whole?How much down time for matenance will the engine need in 2-3 years when long hours on fires & abuse start to add up?
Lol. All the people commenting on the flaws of electric vehicles as if they're completely unviable are stuck in the past.And your point is???
Horses are still relevant in todays world, just ask the Amish
I’ve watched the video as well as sever other videos on this electrical fire engine as well as other electrical fire enginesI encourage you to watch the first minute of the video. It quickly summarizes how the electric works.
In summary, they quote 2 hours of pure electric use, and then an additional 4-6 hours of use with the diesel generator before needing to refuel.
First, yes the diesel extender can certainly be run while people are inside. It’s a lot like a traditional Diesel engine where it exhausts outside.
Second, just like today’s diesel trucks I’m sure you will want to have at least one person awake while the engine is running for safety. But that’s nothing new and existing protocols would handle that.
They didn’t quote a lifespan.
For the Diesel range extender I would expect less maintenance since it will see significantly fewer operating hours than the traditional Diesel engine in a fire truck. Additionally, it’s likely a much smaller engine.
For the truck as a whole, electric generally requires less maintenance due to dramatically fewer parts. This is me extrapolating from current electric cars, so can’t say definitively for the fire truck, but I don’t see how it would suddenly become more overhead than an internal combustion engine.
To clarify here: if the truck is recharging back at the station, then almost certainly there would be no need to have anyone awake or monitoring the truck.Why would you want a exhausted fire fighter staying awake to recharge the electrical engine instead of getting much needed sleep when it takes less than 10 min to refuel a diesel engine
Gotcha. In that case everything will be essentially the same when it comes to durability/maintenance except for the powertrain. Since the rest of the stuff is shared with a pure-diesel fire engine.Engine refers to the entire vehicle and all onboard systems as a example the water pump needs yearly pump testing
So it’s optimistic to say 8-10 hours max on a fireground before needing a diesel recharge
How long can a normal diesel fire engine run on a fire before needing a diesel recharge??
Most engines, ladder trucks, and other large vehicles such as heavy rescues, get anywhere from three to five miles per gallon of fuel. And an idling fire engine uses two gallons of diesel fuel every thirty minutes.
