So I have been running it for the last couple months. I have some pros and cons but over all I think I like it. I did get it on a steal which was nice but I think if I paid full price I still would have gotten it.
Cons
-cord is kind of annoying. I chose not to wire through my dash because of the time to do it all so I ran it outside the dash between the door and the dash. The fault is my own but still it either a ton of install time or unsightly cord.
-When I first set it up it took some time to learn when to turn off and when to stay on so I had to reset it a couple times to get it running smooth
Pros
-It tells you when you are doing a regen cycle which is nice. Seems like a lot of people struggle to tell when the regen has started and I even ran into the problem of turning it off mid cycle.
-Exact engine temp, transmission temp, load%, fuel levels, and about any other diagnostic you need while pulling or just in general.
-Ability to pull codes and clear as needed. I went into limp mode after I had my fuel gel up. Pulled the code googled it and sure enough. We did the maintenance needed and back on the road. No second guessing the issues and no need to go in to see why the check engine lights on.
