Duratrac Noise
I bought my truck with 28k on it with what I assume are the original duratacs. One of the first things I noticed was how loud the tires were. I'll be getting new ones sooner rather than later
I ended up ordering Terra Grappler G2’s. I stayed with the 285-75R18.
  • Like
Reactions: ccw
I have put 25,000 on my 2020 and driven cross country with them and the noise is minimal for how they have worked off road.
I just replaced mine at 31k miles of driving and another 16-17K miles being towed behind RV. They were REALLY noisy. Brand new ones are very quiet. Always happens when replacing almost any tire make/model. They just get noisy as they wear. Mine were bad so very happy now.
I just want to make sure I understood this correctly, you towed a tremor behind an RV?
I ran Duratracs (C-rated) on my 99 Wrangler TJ and loved them. Ran Ridge Grapplers (E-rated) on my 18 JL Rubicon and loved them too. But what these folks are saying is true. They get a bit louder as they wear. I don’t have my Tremor yet but I believe the Duratracs are E-rated, which is fine by me, especially off-road or on the rocks.
Do you guys think it’s worth another $50-$70 per tire to get Ridge Grapplers?
I only have 1,000 miles on my Duratracs so limited experience and no winter driving yet. They drifted all over the road for the first 600-700 miles but have settled in now. I had Ridge Grapplers on my last truck and LOVED them. They were as quiet as any all-season radial I've driven. The Duratracs are louder but not horrible...yet. I suspect these will get annoyingly loud as they wear. My next tires will be Ridge Grapplers again.
I’m considering a set of DuraTrac’s for my 2021 non Tremor. I know that the Duratracs HOWL once they get worn and if not rotated regularly. Question is if they are also loud when brand new too? Or is it just once worn or if not rotated enough?
I don’t mind a slight hum but do not want to whomp whomp whomp down the road on brand new tires.
I sincerely am not having ANY of the problems that so many of you seem to think you're having with these tires.. in fact they are BY FAR the best stock tires I've had on a 4 wheeled vehicle yet. I really think that a lot of you guys are running these tires down as an excuse to blow more money on tires that "look cooler". Anyone wishing to part wishing to part with theirs I may be interested in putting them on my other truck.
I have a set with about 10k miles that I run in the winter, and during summer I put my regular Michelins (I'm a faux tremor :p) and the Michelins were noticeably quieter, but honestly it was a pretty minor difference. There's a minor hum with the Duratracs, but IMHO the grip is worth it when the going gets tough.
My Duratracs with 48,000 miles are much quieter than than my Ridge Grapplers were at any point in their life. I'm projecting to get 52,000-55,000 miles from my Duratracs. (2021 F350 Tremor, 6.7)
I got about 45,000 out of my Ridge Grapplers. They seemed to have a "harder" rubber than the Duratracs do. They were more aggressive and wore a little faster that the good years. They are also about $100/tire more than Duratracs are. (2017 F250, leveled 2.5", 6.7, 285/75R18, Load E)
I had mine for 5000 miles before I swapped them to get a tire with the 3 peak mountain snowflake symbol. They were pretty quiet to me, and I found them quieter than the Toyo ATIII's I replaced them with. Though not silent, which is expected for their tread design.
It is worth noting that 22MY trucks have DuraTracs with no 3PMS whereas earlier model years did. The current belief is that the tread compound was changed which resulted in losing the 3PMS, so that may have altered the noise they make. As I noted above mine did not have the 3PMS, but something to keep in the back of your mind with reports from others.
Not saying the noise did change, or that it got worse. Just that it may have.
Interesting. At 3.5K miles i can’t take mine anymore. Above 70mph they hum/noise is unbearable .They were quiet up until 3K and then all of the sudden got loud over one day. Now i can’t unhear them. Not sure what happened, i gradually took them down to 50psi between 1-3K, doubt that could have been the culprit. A bit puzzled now. Was thinking toyo at3s in 37 but you’re saying those might be noisy too:-)
Interesting. At 3.5K miles i can’t take mine anymore. Above 70mph they hum/noise is unbearable .They were quiet up until 3K and then all of the sudden got loud over one day. Now i can’t unhear them. Not sure what happened, i gradually took them down to 50psi between 1-3K, doubt that could have been the culprit. A bit puzzled now. Was thinking toyo at3s in 37 but you’re saying those might be noisy too:)
That’s wild. I have no idea why the noise would have changed so suddenly like that. Does it sound like it coming from all corners? Or one in particular?
(Albeit tire noise is one of those things that’s going to be really difficult to pinpoint to a specific corner. Trying to pick out if it’s one tire that may have damage.)
I will say I seem to be in a minority with the AT3 noise. Lots of other folks reporting they’re really quiet. I don’t find them excessively loud (and thus I don’t suspect damage, nor have I found damage in my many tires-off-the-truck inspections), just surprising given the comparatively tame tread design.
The AT3 noise also hasn’t noticeably changed to me over 28,000 miles with them.
True. I had a hard time pinpointing , but seemed to recollected that i noticed the noise driver front before i rotated the tire to the passenger rear. So thinking what you said, i did a thorough inspection of all 4 looking for anything that i could find abnormal. I found this minor damage. Not sure if it’s the culprit, seems silly that something this small could be so loud, but nevertheless i took care of it waiting for it to dry and will inspect the noise after.
Noise is minimal on my 2021
View attachment 133898View attachment 133899View attachment 133900
Ya I can't imagine that making that much noise either. Worth a shot, but I will be very surprised if that makes a noise difference.
All I know is I hate mine. My truck is not even a year old yet, I have 24K miles on them and am over the noise. Looking at the new BFG HD AT as I used to rung the ATKO on my old F250 but they do not support the weight I need for my 5th wheel when we travel. The new BFG HD are the same weight rating as the Duratracks so I am thinking about giving them a try plus they are a commercial rated tire hoping that I get more usable mileage out of them.
