Hey guys, having a little trouble here figuring out how to configure this setup I have in my mind.
I have the dual fogs kit from Baja designs. I want to be able to operate my squadron pros from both my upfitter switch and a relay triggered from the high beams.
I’m having a brain fart on how to do this.
My plan was to use a 4 pin relay and connect the high beam trigger to pin 85 on a jd1912 relay and connect the output on pin 87 to the lights.
My concern is backfeeding the upfitter switch from the relay and backfeeding the relay from the upfitter switch.
I know some diodes are needed but I’m not 100% sure where.
My other thought was to run the output from the upfitter as a trigger to the relay also on pin 85 and put diodes on both the upfitter lead and the high beam trigger lead.
