- Jul 16, 2026
- 12
- 11
- Army Civillian - Vehicle and Mechanical Inspector
- 2022 F-250 Tremor 7.3 Gas Supercrew
- 2013 F-150 FX4 3.5 Ecoboost, 2011 F-150 King Ranch 3.5 Ecoboost
So I pulled my RV from Texas to Nebraska as well as drove into Denver and back into Nebraska unloaded. I got a P2227 when I arrived in Nebraska and unhooked. So, I cleared the code and moved on. Drove to Denver airport to pick up my son and the code popped up again. Cleared it again and drove back to Nebraska. Well no sooner than I arrived the P2227 code came back. Puzzled i looked into it. I could not find a Baro sensor in parts nor could I locate a MAP sensor for the truck with a 7.3 gas engine. I still do not know if they are present or not
Supposedly the system works off of a preset range of calculations in the programming. When I was driving from one extreme to another, the computer could not recalculate fast enough and would kick out this DTC.
So..... the solution , which I am not impressed of by any means, is to stop as you begin the change altitudes from one extreme to another. Once parked and everything is off, check your baro reading using a scan tool. Turn on the ignition only and let it sit for 45 seconds to a minute. Mine went from a 25 to 28 when I accomplished this and the truck begain to run better. I found myself performing this operation every stop for fuel.
