While not the first I figured I'd toss this up here. I was looking at the Morrflate stubby and hoses. I then just took a look at Amazon and how much it would cost to roll my own. Net this build was around $30 less to build myself. Since I run higher pressures in the rears, my build will just do two tires at a time. Though it could easily be adapted to do four.
What you need:
A roll of teflon/PFTE tape.
A couple adjustable wrenches.
A bench vise if you have one.
A gauge with 1/4NPT threads (https://smile.amazon.com/gp/product/B07T6HZ8XB)
A shutoff valve with 1/4NPT threads (https://smile.amazon.com/gp/product/B0823QBKFV)
A 4way air manifold (https://smile.amazon.com/gp/product/B07KCRBL8B)
Add them all together and you get this:
I use and like Flexzilla hoses. So that is what I went with. I bought a 50ft hose and cut it in half. Then added two new ends on the cut side. To lock onto the valve stems I went with Haltecs.
Parts needed:
Hose fittings X2 (https://smile.amazon.com/gp/product/B007QV1F6E)
Flexzilla 50ft Pro air hose (https://smile.amazon.com/gp/product/B007QV1UDW)
Haltec air chucks X2 (https://smile.amazon.com/gp/product/B01938M8MW)
1/4 FNPT plugs X2 (https://smile.amazon.com/hose-fittings-Coupler-Plug-Quick-Connect/dp/B074SY2L13/)
For 2x 25ft hoses I haven't found a nice bag to keep everything in. If you go shorter with the hoses 10-12.5ft this bucket boss bag will hold it all nicely:
Lastly this is setup to run off my air compressor. If you have an ARB, Viair etc you'll need to build an adapter so that you can actually hook your compressor to the manifold.
What you need:
Parts needed:
