DIY Install: ARB Twin Air Compressor in Engine Compartment (7.3l w/ dual battery)
Reviving this tread, as I installed an ARB Twin this weekend, in the engine compartment next to the 2nd battery. 7.3 Gas so plenty of room.
I used the approx 4 inch unused slot bracket down on the frame below the battery, to hold the bottom of the mounting plate fabbed from 1/8 sheet aluminum. The Ford mount supports the weight well, and a 1/8 sheet aluminum fits perfect, put a small piece of rubber underneath to reduce vibration and wear.
I did have to lengthen the ARB wiring harness another 2 feet to safely wire into the main battery and ground at the BMS stud. Bought a hydraulic crimper at Harbor Freight for the 8ga line connectors.
The purple solenoid trigger wire is also connected to Upfitter switch 3 in the cab.
I then ran a braided hose down to the ARB chuck I installed next to the fog light. This will be temporary until I buy a flush mount version that another member sells.
Any questions, happy to answer 👍
- Mark
I did something very similar
- Mark
I've been trying to determine how was going to wire my twin compressor from a bedside mount and didn't even consider the engine bay. Popped the hood this morning and holy crap, that's a lot of room to work with on the 7.3. Engine bay seems to much cleaner and I don't have to worry about a 10ft long electrical run and keeping it out of the elements. If you have any closer pics of how you mounted it at the bottom of the battery, I would be eternally grateful. Also, I assume that you extended the power wire to the passenger so that you could tie it into the negative bms? Wondering what would be the downside of wiring to the driver side battery and wiring the relay to an upfitter swith. Thanks!
Hi, yes I like the location as well, and have an external quick connect mounted next to the driver side fog light. The only consideration I would call out is engine heat for the under hood location. I don’t think it’s a huge deal, but I may add a heat shield of some sort to deflect a bit.
To help mount the plate and bear most of the weight, I placed the 1/8” plate down into a small bracket that the factory places below the battery tray. I’ve added a pic with this outlined in Red, ignore the text. I added a piece of rubber hose down in the slot to reduce wear and vibration over time.
I considered connecting to the DS battery, but there was no stud to mount the Positive cable to on my battery, and I didn’t not want to cut the OE clamp off and rework that. If you can figure this out, would be a lot easier!
Be aware the ARB wiring length is just a bit short if routing up and along the firewall to the PS battery. I added 12” of 6ga wire to easily route the way I wanted. There is a separate wiring run in front of the engine for the DS battery lines, so that’s perhaps a good option if needed.
Ya, I ran the ARB purple trigger wire to the #3 Upfitter switch wire under that little Upfitter box. No additional relay needed actually. There is an additional small ground wire to connect too, related to the internal switch in the compressor (pairs with the purple trigger wire circuit).
Good luck, let me know if you have more questions 👍
I appreciate all of the details. I was also thinking about adding a heat shield as well. I'll add to this thread once I get mine mounted.
