Dirty Engine Bay
Done it plenty of times. Cover the fuses on the passenger side. Never use direct spray, use the shower/misting nozzle. Get a good mist/spray to wet everything down. Spray a cleaner if you choose. Rinse. Go back and wipe down any other areas that need more attention. Less is more in this activity, no fire hose required. Even a pressure washer can work good, but we aren't trying to direct the water INTO the engine....just helps get a good misting action to wet the whole area. 😎 😎 🇺🇲 🇺🇲 🇺🇲 🇺🇲 🚿🚿🚿🚿🚿🚿🚿🚿🚿🚿
Follow the guidance in the Owner's Manual :
When washing the engine compartment:
• Never wash or rinse the engine while it
is hot or running.
• Never wash or rinse any ignition coil,
spark plug wire or spark plug well.
• Cover the battery, power distribution
box, and air filter assembly to prevent
water damage.
Note: If your vehicle has an engine cover
remove the cover before application of
shampoo and degreaser.
• Spray an approved engine shampoo
and degreaser on all parts that require
cleaning and rinse with water
@HeavyAssault huh, I always thought you had to make sure you got the dirt out of the small tight spaces. :D
@MackDaddy33 In all seriousness though when it comes to engine bay care, the goal is less about perfection and more about awareness and consistency. Engine bays naturally accumulate dirt, leaves, and environmental fallout, especially depending on climate and driving conditions. Simply making a habit of inspecting the area and occasionally blowing out debris—particularly around the front cowl—goes a long way toward keeping things manageable and preventing buildup.
Washing an engine bay is generally safe when approached with restraint. While electrical components don’t love direct water exposure, it’s worth remembering that engine bays are already exposed to moisture during normal driving and rain. Light, controlled rinsing is typically fine. If using a pressure washer, lower pressure is preferable, wide spray patterns are safer, and avoiding prolonged focus on any single area is key. The intent is more “gentle rainfall” than forceful spray. For those new to engine bay washing, covering sensitive components isn’t a bad idea and can add peace of mind.
For deeper cleaning, chemical choice and dwell time matter more than aggression. A good all-purpose cleaner or degreaser allows dirt and grime to be chemically loosened rather than mechanically forced off. Common options like Simple Green, Purple Power, or Meguiar’s APC work well, though they may require multiple applications on heavier buildup. Citrus-based cleaners tend to be more effective and user-friendly if you’re willing to spend a bit more. Regardless of the product, it’s important not to let degreasers dry on surfaces and to follow them with a thorough rinse or shampoo to remove residue.
Light agitation with a soft-bristle brush can help activate cleaners in stubborn areas, but this should always be done carefully and away from major electrical components. The same cleaners used in the engine bay often serve double duty for wheel wells, undercarriages, and tires, which makes buying concentrates and adjusting dilution ratios a practical approach.
If available, tools like foam cannons can improve coverage and control, helping cleaners work more evenly and reducing the need for aggressive rinsing. Overall, the guiding principle is moderation: less pressure, more dwell time, and a careful, observant approach. Being cautious and deliberate will yield consistently good results without unnecessary risk.
Happy detailing.
FYI…
I use the green stuff myself, just know they have other products better suited for various applications.
