I used two Upfitter switches, and from what
@Alpoba posted it looks like he did the same (
@Alpoba correct me if I'm wrong). One switch triggers the Primary light and the second switch triggers the Backlight. At least on mine both lights do not work at once. It's one or the other depending on which Upfitter switch you use. If I flip both Upfitter switches on at the same time the internal light circuit only powers the Primary light.
The three way switch provided by DD is the same as using two Upfitter switches. The OFF position is the middle and the Primary and Backlight have their own trigger positions on the switch. Only one can be switched at a time.
The schematic for the DD wiring harness
@Alpoba provided shows connectable harnesses labled "C" for using the three way switch, and "D" for using the Upfitter switch connections. I used the "D" harness to connect to to the two Upfitter switches I used.
