DEF questions
Loshad
Tremor Aficionado
Commiefornia
Navy
2021 F350 Platinum Tremor 6.7
!. Our DEF tanks are heated, yeah?
2. How does the truck know when to turn the heater on?
3. If it sits all night at 20F then it's probably a good idea to let it idle a good while to heat up the DEF, especially before towing, yeah?
4. If I get low on DEF should I play some Def Leppard?
The pump and also the line is heated as it is easier for it to freeze in the lines than the tank. I believe it is based off ambient temp sensed by the truck (same temp as displayed in your screen)
The freezing point of DEF is 11F so no worries until it get close to that. I’ve never waited starting heavy equipment with def. I wait a minute or so for oil to distribute then idle it very high (1500-2500) until coolant and hydraulic shows a little warmth.
I don't keep my tank topped off in the winter ( def tank) in the unlikely event of a freezing. I keep mine 1/2 to 3/4 in winter. As it last a long time. I haven't had a problem with this one or my other older one ( 2015). In fact up in the north woods winters its common for -20 F at night. They always start right up no trouble. You can plug them in overnight too.
