Decreasing Interior Road noise, Wind Sounds and Raining sounds from the roof.
This young man does a great job explaining the headliner removal. In his video, you can see the thickness of the headliner itself and the roof under the headliner. He has a sunroof but you'll get the idea. It may be possible to install some closed-cell foam noise cancellation material up there on top of the headliner. You'd just have to be strategic in the placement keeping attachment points in mind.
As part of my audio build, I also purchased the SoundSkins pre-cut sound dampening kit.
I've only got as far as buying the Latex Tubing. The Florida summer heat is here, that puts outside projects on hold. I did get an estimate to have my truck done from a local Stereo Shop. Floors, Back Wall, Ceiling and Doors. $2,000. I'm still going to do the tubing one door at a time, maybe early fall.
Let me know how the tubing does been thinking about trying that
I installed the tubing in my 2015 F250 and it made a noticeable difference. You can pull the weather strip off and bring it inside to do it. Maybe use a non-toxic lube to help tubing slide through the weather strip. Something like what the electricians use when pulling cable.
It's been incredibly hot up here in NE Florida too. Don't blame you for minimizing work outdoors.
What size tubing is the best? I've seen where some say 5/16? Is that right?
This guy said that 3/8 was too much and that he was going to do 1/4 silicone tubing instead.
