Debating between 2 level kits need help
If you want adjustibilty and longevity, they are the best option. That with their S&B tunes shocks along with the steady track system is one (if not the) best steering/handling setup on the market.
anyone have any experience with this?
Can these be used with basically any lift/shock? I’m wondering if any harm in adding to allow fine tuning/dialing in heights if going to have things torn apart.
Never have seen this before. Or am I overthinking it? 🤔
I'm assuming this would not impact the onboard scale / smart hitch, is that correct?
If it's a puck, it's a no-go. Bad for the geometry.
After reading that thread I wonder if just a reverse level is all I need and upgrade shocks all around with some Bilstein 5100’s. Call it a day and save some coin.
Since you really don't need a lift up front to install your new tire size you want, the lower block in the rear with good shocks will probably be best for you, get the truck more level, and less expensive. Easy Install.
If it's just a street driver than 2" shocks should be fine.
