CP4 ignition pump replace?
The CP4 that Ford is using is "rated" to run on our ULSD. The fuel isn't the issue, the issue is if there are contaminants in the fuel that get by the filter system; be it water or other contaminants.
Other high pressure pumps are susceptible to water or other contaminants too if it gets by their filter system. Other designs though, don't send the remnants of a tore up fuel pump the the injectors, fuel lines and every other part of the fuel system.
CP4 failures are reasonably rare; a CP4 failure due to something other than bad fuel are EXTREMELY rare.
So what would you say is the number one reason for a failure... Water or air? And if we can drain the water from the separator and eliminate water, how can air get into the pump?
I would guess that water is the primary cause of failure. But I have no actual data on that.
Air can get in If you don't prime the fuel pump completely after drain your water separator.
I typically key cycle my truck 5-8 times after draining my separator while standing outside my truck (it's pretty audible when the pump is priming)
