Hi everyone. Am posting this to try and solve an issue with my 21 F250 7.3 tremor. Recently I keep getting check engine light telling me my truck is not getting up to temp fast enough. Upon a little investigating I've came to the conclusion that's its likely one of two things. 1) bad coolant temp sensor or harness. 2) malfunctioning thermostat. I'm leaning towards the sensor for the following reason. The check engine light will come on, stay on for a day then clear and go off by itself. Furthermore, it sometimes won't come back on for another 500 to 1000 miles. This brings me to my predicament. I am trying to find the location of the temp sensor to change it. I found what looks like the connector end of the sensor in the top of the water pump itself. Only problem is that there is no way to remove it because only the connector is visible. Any suggestions would be appreciated.
