No quite yet... but we are working on it.Can one do paddle shift without changing steering wheels and dealing with the airbag?
And works with adaptive steering?No quite yet... but we are working on it.![]()
It is because of the adaptive steering that we are working on this upgrade. I personally think it will be BIGGER and more popular than just our Raptor paddle shifter harness!And works with adaptive steering?
Here is a video I put together showing some of the process to install an F150 floor shifter in a 2020 F250. This will apply to other years with minor adjustments. I know some of the first questions will be why, and the simplest answer is because I wanted to. But when my wife asks it is because I greatly prefer the floor shifter playing in the dunes. Plus, I wanted to. This will also be helpful if you are needing to remove parts of the console for any reason, or if you were curious what is inside.
I believe you could install the shifter in an existing console, but would require figuring out where the shifter mounting holes and drilling them. From what people have said a company makes the wiring harness you need to run to shifter, which would help, as you mentioned. There may be a cable out there, but with the research I did it was either modifying the cable or the mount on the side of transmission. Only thing I don't know is the top cover, if you would need to modify the existing, or if you could buy one that would go into that console and line up with the clip holes.Hi,
Thanks for posting the video. I am willing to try it but I have a few questions.
Can I keep my original console and just buy the shifter, cable and a new F150 shifter and cupholder trim?
Did you have to modify the cable that you ended up using?
I don’t feel comfortable messing with the wires, so my plan is to buy the harness.
Regards
Not sure why you would have had to modify a cable from an F150. We have sold many of our column shifter to center console shifter harnesses and informed our clients to order an F150 floor console shifter cable.... and no one had any issues with their install.I used a 2018 F150 cable floor shift, and then I either needed to slightly rework the cable bracket on the side of the trans, or the cable, and decided it was easier to cut the end of the old cable and weld onto the new. It was a hair short, so just needed to make it a little longer.
