Cold air intake problems
Looks like the OP has a 6.7L... all those commenting after putting one on a 7.3L need to understand the air management and control system on the 6.7L is orders of mangnitude more complex than our gassers.
I have no doubt that a 7.3L can handle swapping to a CAI without issue.
A 6.7L is going to have models to predict the airflow at certain engine conditions (steady state, DPF regeneration, transient) using a number of different sensors and engine models as primary inputs. If the MAF (does the 6.7L have a MAF sensor?) is reading a different value than the ECU expects, a fault code can easily trip.
A 6.7L is going to have models to predict the airflow at certain engine conditions (steady state, DPF regeneration, transient) isung a number of different sensors and engine models as primary inputs. If the MAF (does the 6.7L have a MAF sensor?) is reading a different value than the ECU expects, a fault code can easily trip.
Gotcha, makes perfect sense and good to know it's a 6.7 diesel. However, everything you mention is easily dealt with, just a little more involved than the gasser.
MB
You guys are cracking me up with your comments!!!! LOL. One man said it right. Just pay attention and learn and 100% CAI, tune, exaust change (I will leave it at that) and omg your truck can breath again and it is a MASSIVE GAME CHANGER. My truck has 650HP & gets about 20MPG in the city with 38's on 22's with a 5" BDS lift. I will have this truck until I die.
I put a K&N CAI on my 7.3L 2023 Tremor. It removed all stock boxy looking thing of a restrictive intake under my hood with a box to the throttle body. The entire air box was removed the replaced with a bigger longer filter and a smooth tube for the air to flow to the engine. More air = more power
Also included in the paperwork was a dyno sheet for a 7.3L gas burner showing 12 HP gain.
I did have to clean off my mass air once as it seemed it had a slight hunting at idle suspected filter oil cause this.
All good now. I can tell there is a difference in performance.
When you get on hard, It sounds like one of those old quatra-jet 4 barrel carburetors, when you flipped the breather lid...
Some of ya'll might not know what I am talking about....
I am waiting on 5 Star to get the 2023 7.3L tunes ready to go and available.
