Center speaker and tray removal/install pro tips!
Vigilance247
Silverback
Texas
USN
2021 F-250 6.7 "Silverback"
2015 Corvette Z51 "Vettenessa"
I decided to install a dash mount for my iPhone. Installing the dash mount was super easy and fun to do. The major problem I ran into was all due to previous repair work. That repair work was needed because Safelite did not seal my replacement windshield correctly and rain water ran inside my truck and ruined the infotainment system. Safelite paid the Harlingen, Texas Ford dealership to replace my infotainment system. The tech who worked on my truck broke all of the black plastic tabs on the speaker grill. The tech also lost half of the white clips that hold down the speaker grill and the tray. That explains why the right front corner of the dash tray was slightly raised up and probably the cause of the rattling noise I have been trying to find. Since I don't know much about car interiors, I called my buddy who recently retired from Ford. He told me that the white plastic clips are sold on Amazon. Here is the part number if anyone else needs those white plastic clips: Body Trim Retainer for Ford W714972-S300. I used my Wagner heat gun on the lowest setting to quickly soften the black plastic tabs and then I gently squeezed them back together with needle nose pliers. WORD OF CAUTION: that black plastic gets soft in seconds even on the lowest heat gun setting.
My 3 pro tips for removing the center speaker and tray are: 1. pre-order a few white clips just incase you lose one. 2. park in the sun to warm up the dash plastics so they will not be brittle. 3. when removing the speaker grill and tray, use a plastic trim removal tool, take your time, keep the speaker grill level and lift straight up. If you tilt the speak grill and try to pry it off then will you break the plastic tabs.
