CEL, DEF Gauge, and No code - strange
STDevil
Washington (the one in the West)
Super Duty
Hi all -
My 2021 6.7 Lariat has been a great truck. It's got just under 30k miles on it. Last weekend, we did our last RV trip of the year. I noticed that the DEF gauge was reading completely "full", even though I am pretty sure I did not have a full tank the last time I drove it.
When I took the trailer back to the storage lot, I noticed that I was not getting the usual "ticking" noise near my DPF (where I assume DEF is being injected). That combined with the "full" reading on the DEF gauge started making me wonder what was going on. Then, when I got back in the truck, I noticed my check engine light was on :(.
When I got home, I took out my trusty code reader (Innova) which I purchased in 2008 or so, and plugged it into the truck. It said there were no codes. I am guessing that the firmware may need to be updated and will look into that later. But if any of you know for sure, it'd be good to hear.
Some internet searches took me to some posts discussing a P20EE code. That sounds potentially nasty because in some cases, it looks to require replacement of the DPF!
If anyone has had experience with this, it'd like to hear what happened.
The good news is that I bought an 8 year warranty from Flood Ford so I should be covered cost wise.
Thanks...
Depending on the miles driven you might be under the factory emissions warranty.
Two things with this... did you have the recall performed for the "sensor" to be put in and enabled that was not put in at the factory for COVID? Once this was done on my 21 my DEF usage went way up. Also, on the 20 - 22 MY's, the DEF sensor could sometimes "stick" has been reported. My 21 DEF gauge was manic at best and not at all tightly accurate. I knew when the gauge said 65% that it would take a full 2.5 gallons which would mean it was off by about 5% to 10%. Mine would stick at 100% for 2000 miles then all of a sudden would fall below 90%.
That said, I switched to platinum DEF (yes DEF is DEF as far as the actual SOC is concerned) because of the lube property and additive in it that helps with caking and fouling the nozzle. Once I did that, the gauge seemed to be a little more active but still not tightly accurate. So, long story short, your gauge might be "sticking" a bit. Try adding 2.5 gallons of the platinum DEF and see how much it takes. As the new slick DEF mixes in and flows through it might help the gauge. If you aren't seeing any soot, no codes or rate limit messages and your exhaust still smells like ammonia and not diesel then it might be worth a try.
Nice for those of us who just bought it cause it was Platinum! :ROFLMAO: :ROFLMAO: 😜 😜 😜 💰 💰 💰 💰 💰 💰
Peak platinum def?
I had an experience with my def tank creating too much vacuum. Showing it was full until it wasn’t sucking anything up. I got a no prime error code. I popped the def cap filled up the 3 gallons or whatever is max full, and after a few hundred miles it cleared up. Changed a seal on my cap and boom no problem since.
I get my DEF at the local Pacific Pride Stations. They go through it quickly so I am assuming it's fresh.
I got my truck in February '21, just as we were starting to hear rumblings about shortages and such. So mine came with all the parts and pieces.
It's wierd that my code reader says there are no codes. Does anyone know why this might be happening?
Thanks...
2008 is approximately when you bought your code reader. That is around when they brought in all the emissions on our trucks. Could it be your code reader is too old?
I am guessing it is. I will see how to update mine or get a new one...or just wait until I take it to the dealer...
What does ford pass say? Also try just calling your dealer and asking if they can look at your code remotely. Yes they can do this, and will take less than 5 minutes on hold.
Thanks my phone said I had a low DEF pressure condition. I took the DEF cap off this morning (It was that neat locking one that one of the forum members made), and got this huge whoosh. The tank was under vacuum. I drove to the local gas station and noticed that the DEF gauge was now reading about 3/4 tank. When I got to the station the CEL light was off but they pulled a P20E8 code which means "reductant pressure too low". Which I suppose makes sense if the tank is under vacuum.
QUESTION: Does anyone know how the tank vents? I see a small hoze that runs parallel to the filler hoze, but it just runs up to the filling hole.
So the OE cap appears to have a vacuum breaker (don't ask me how I figured that out...). I am going to reinstall it and see what happens...
@BroncOh has a fix for this, he shipped me a replacement while I was on my month long road trip. No issues since
To close this one out, please refer to the locking fuel cap thread. There was a blockage in the DEF cap "venting system" and the supplier provided excellent instructions on what to do. Problem solved...
