Carli pintop shock issue
Rooster
Tremor Junkie
Tremor of the Month 🏆
Montana
Navy
2022 F350 Platinum Tremor 7.3 w/winch 2020 F350 Platinum Tremor 6.7
2013 Jeep JK Rubicon or 2018 KTM 1290 SAR
I had a diesel. Installed the rear shocks on it. sold em got the gas version when I got the 7.3 and got around to putting the rears on today. They don't fit in the lower bracket. The bushing is too wide. Anyone have this issue?
I'd think all the tremor shocks are the same width for diesel vs gas from ford. Im thinking the shocks were mislabeled or a wrong bushing got put in?? @BLACKCHERRY
Inside length on my brackets is 1.56 each side
I'd think all the tremor shocks are the same width for diesel vs gas from ford. Im thinking the shocks were mislabeled or a wrong bushing got put in?? @BLACKCHERRY View attachment 62254
View attachment 62254View attachment 62256View attachment 62257
Interesting. And that inner adapter is not removable?
No or at least I don't know how. it even says in the instructions that's it's 1.5" so I'm guessing it's wrong shock or grabbed the wrong bushing.
I don’t know anything about it, but I noticed that the sticker on the box says years 05-17 and you have a 22. If that was the only interference I’d just grind it.
Don't want to grind it. It should fit, the sleeve I think just changes it for the other years. think their labels just say that 17 on is the same so they haven't updated them. Did notice on my box it says AS-FPT25SPKG-LVL-11-GAS instead of CS-FPT25SPKG-LVL-11-GAS like everything on Carlis site and CJCs, can't find the number on my box on either site. Sucks I found it on a Sunday
I haven't had my hands on those shocks but often times the spacers are just loose in the joint. Also, the joint is held in with a snap ring. Maybe they included the wrong spacers, or bad batch.
This picture obviously isn't a King shock but shows how the spacer is just a loose piece that slides into the joint, and kinda shows the snap ring. The King may use a completely different type though. Seeing the zip tie made me think it might be like this.
there's a sleeve in there you slide out of 17 and up, spacers up top come out but the bushing on the bottom doesn't, at least not easily. Hopefully find out something tomorrow
Those are the wrong misalignment spacers.
14mm x 1.667" is the spec on most ram application and front, lower Super Duty.
14mm x 1.5" with a 14mm/12mm reducer sleeve (to be utilized in 05-16 applications with 12mm hardware) is the spec on the rear, lower ford shocks.
Shoot me an email with these pictures - [email protected] - I'll get king to drop-ship you some spacers!
Awesome thanks! These did have the sleeve in them.
Awesome, so it sounds like the spacers are removable like in the comparison photo I posted. Easy fix. Is there a chance that the spacers were mixed up, the rears belong to the fronts, fronts to the rears?
Yep, that was my concern above too, it appeared like they were not removable in that photo.
Didn't look to me like they were. Dan said it was pretty easy as did cjc. I pushed and pulled on em but they didn't budge. Happy I don't have to wait another 3 months for shocks. Carli and CJC customer service was great as always.
