Carli Leveling Kit with Full Progressives + 1" PMF Block?
Bigzaj
Tremor Buff
Houston
Ford Raptor
I am looking at getting a full Carli E-Venture leveling kit with the full progressive rear leaf springs. My understanding is that the kit comes with a 2 degree shim for the rear springs to correct the pinion angle. I purchased 1-inch PMF blocks with a 2.5 degree angle that I was planning to use in place of the shim so that the truck maintained a bit of rake to it. Has anyone done this or is there in issue in doing this?
Thanks.
Before I ordered my blocks I spoke with a guy at PMF and he confirmed 2.5* taper. I’d assume same goes for a 1” block but you may confirm. I got the blessing from Carli as well that it wouldn’t interfere with anything. I too prefer the look of the rake. When my backcountry shocks wear out I’d love to upgrade to the e-venture.
For the rear suspension stuff just remember 2.5*. Either use the 2.5* shim and a 0* block. Or no shim (hence 0*) and a 2.5* block.
My plan is no shim and the 2.5* block
