Carli diff guard = leak
SteveG75
Tremoraholic
Redneck Rivera, aka Lower Alabama (FL panhandle)
USN (Ret)
2022 F-250 7.3 Platinum Tremor
1975 Corvette w/ 496 big block
So, installed the Carli front diff guard this past weekend. All bolts torqued to 33 ft lbs per instruction. When I pulled factory bolts, bottom left bolt leaked oil. Cleaned it all up on install
Drove truck today and decided to check diff. Could feel oil inside diff guard and bottom of it was wet. No drips. Level was good. Pulled bolts and added non-hardening sealant and retorqued. Only other thing I can think of is the factory diff tag is preventing a good seal since it does raise one edge of the diff guard slightly.
Any thoughts? Should I remove the factory tag so the diff guard can sit flush? Wife is asking if I have already broken the truck.
The installation instructions on a different brand of diff guard I was looking at had this caution:
That was one reason I have yet to install one.
Seems dry this morning. Think I will order a Lube Locker seal and the supplies to refill the diff. Then I can reseal at my leisure.
Just did the same
