I have a 2021 Tremor and am trying to hook up cargo lights to the push button in the bed. Have them wired. All lights come on for a second and then the left side lights that installed flicker and everything goes out. Can't get them to come back on. If unwire the cargo lights on the left side, I can get the right side lights and the factory light to come on. If I hook back up the left hand side cargo light, I get a flicker and there all out again, and nothing will come on. Do I need a resistor hooked up to the wiring or what could be the issue? If hooked to check voltage it is like .6 volts not 12. What direction should I be going?
