Brake Fuse & won’t shift into gear
LariatTremor
Deep South Texas
2021 F-250 Lariat Tremor
Does anyone have the brake wiring schematic for a 21 Tremor? My brake fuse keeps popping and I want to trace wiring to see if it’s chafed somewhere. The fuse that’s blowing is #7 in the passenger compartment fuse panel. It pops randomly, meaning that it works fine for a couple days then pops, and won’t let the truck shift into gear. I’ve checked the third brake light for water intrusion but all looks good there. I found a white/red wire on the passenger side wiring harness that was a little melted and fixed all I could, still need to pull passenger seat and follow wiring harness. Has anyone had this happen and know what to look for?
Thanks, that’s the schematic for the trailer tow module. I’m needing a diagram of the trucks brakes and third brake light. More of the route the wires go without tearing the whole truck apart.
A long time ago, back when I was a youngin', I flipped my truck. Smooth as butter, didn't roll, literally popped it on the top -- the only damage was to the top of the cab and rear bed of the truck.
Long story short, the body shop lifted the bed to work on it. When they put the bed back on they laid the bed over a tail-light wire. I assume they knew this because they had put a 40 amp fuse in the slot.
I drove the truck for days without a problem. That is, until I drove it at night. I turned on the headlights and drove probably 5 miles before that wire grounded well enough to glow -- but glow it did. I saw the glowing wire melt through an air vent, smoke started billowing out of the dash -- and I pulled over immediately. It's a good thing, because the entire interior of the cab was completely engulfed in flames within seconds. Maybe 10 seconds from sight to not survivable. If I'd been on an interstate or something -- I may have still made it out alive but I have my doubts I would have made it out without significant injury (or maybe not made it out at all).
Anyway, I know that's not the information you're looking for -- in that regard apologies in advance, but my hope is my lesson can be passed on; take that seriously -- don't jam a bigger fuse into it. The consequences might be more than apparently some dolt at a body shop thought they would be.
Just my personal experience -- these wires are usually run in a pretty tightly packed harness. You're more likely to find a short at a connection point, in a light, etc than you are a kinked wire. That's where I'd start -- assuming you didn't just want to try and warranty it. If you're handy, assuming you are since your looking for schematics, you probably already know you're better off looking yourself than dealing with the nightmare of in-and-out-not-fixed-right dealer service. Only advice I'd give there is identify it, take it in, wouldn't go poking and prodding too much because once you cross that threshold they'll blame it on you.
Fuses are there as protection. Agreed sometimes it is in the middle of a 2 inch thick harness that you cant see. Also if you fix it yourself and something bad happens, Ford will not cover anything. Just a few thoughts.
I like diagnosing problems myself and learn more of how everything is setup along the way. This way when warranty is up, I can fix most myself. Another reason is that I’m working in West Texas and dealerships out here are terrible with service. It’ll be months before they can get to it with all the work they have.
I unplugged the brake switch at pedal and I was able to install a new fuse without it immediately popping. Might have found the culprit, but strange that I was able to plug switch back in and everything is working as it should now without issue. I’ll see about getting a new switch to see if that was the issue.
