BMC Front Fog Light Kit
I may end up going this route - I can't wait to see how @Vecman 's turn out. Maybe toss it up to the upfitters - one per pair. The question will be if I keep the color black or paint them Iconic Silver.
Do I smell a group buy?
I mean I have the other two companies templates and can make you one with the metal face with the 2 cubes. It just removes our intended “keep the stock look” option.
But we can make anything..
Not necessary. I appreciate it though. I like the look of the cube and S2, just had my mind curious when I saw the other options you send with the kit. Can’t wait for this to get sent out. Thanks!
And how do I do that? Where do I find the "fog signal?"
You can t tap the stock fog wire as the relay trigger. It just needs an off / on signal. So the draw is not an issue
I understand that, but again, how do I find the stock fog wire?
I imagine it comes out the back of the factory fog light...
There are (I think) 2 wires there. I wonder if it matters which one I tap. And I was thinking the tap needed to be at the factory fog light switch before the powered wires from the battery. But maybe the circuit is much simpler than I am thinking it is.
One is ground and one is positive. A test light can tell you which. Then T-tap it and run to a relay
Correct me if I'm wrong, but I don't think you can do this if you have the OEM LED fog lights due to the CANBUS system.
Behind the factory switch in the cab, I wouldn't know how to figure out which wire to tap into for the fog lights.
You are right, we really don’t recommend it
I think I may plan on this being the OEM black style color and run it to an upfitter switch. I just need to figure out what lights I want to run.
Q: Is the OEM black style housing smooth or is the finish rough? @BMCLIGHTS
Run the one that will allow you running lights in yellow, then the choice becomes easy. If i went with this bracket thats what i would do.
@BMCLIGHTS do you have a single photo with 2 3” diode pods. I was not able to see even one between here , fb or your instagram pages.
No, not one person in the pre-orders selected one so after we did the test fit, I haven’t had anyone put them on their truck for pics
Main Covers, 2 bases, 4 light brackets that we had to custom make because generic brackets the lights come with won’t work, 3 light surrounds .. All stainless. Not just brackets
and you're paying for the engineering and the cost of the equipment that it takes to build something like this. I don't think people realize how expensive good 3D scanning equipment costs. Can't wait for my setup to show up.
I saw an email the said they should be ready by months end. He is behind on orders though. I’m on a 5 week wait for my hitch lights so far. Haven’t gotten a tracking number yet.
Thanks for the info! BD is an awesome company to work with and I understand the delays.
