BLIS & Cross Traffic Faults - What have I done
Badger203
Tremor Fan
PA
First Responder
Retired
22 F250 Raptor
I’ve have my truck a little over a month and have been adding Mods. One day last week I got messages on the display indicating a fault on BLIS and Cross Traffic systems. (Same sensors I presume.)
I have been back over all the mods and nothing seems out of place. Before I go to a dealer; I thought I’d reach out here for suggestions.
MODs to date
Utility back up lights under rear bumper. Powered from an upfitter switch and backup light trigger from the trailer plug. I got all the power from the trailer harness behind the rear bumper. BLIS had no errors after install.
The next MODs were done the same day and the error came up the next day.
Boost Auto sequential lights in mirrors.
Everything worked following install and there were no error messages. I didn’t specifically check the BLIS, but nothing appeared to be wrong.
DRW 3 Red LED under tailgate. I bought a genuine Ford part and the premade wiring harness from the popular video on here. I had some issues getting the pin in the slot and thought this may be the source of the problem. I’ve checked, rechecked and triple checked the connector and there are no lights out and the pins are aligned on both sides.
After the 3LED bar was installed it was dusk, so I checked all the lights on the truck. None were out and there were no warnings on the dash.
It rained overnight and the next day I jumped in and immediately on turning on the power the warnings came up.
Forscan has the DTCs and they won’t clear. It says communication with the BLIS has been lost. The fuse for the BLIS (#17) is not blown.
What did I do? Where should I look next? Is the plug on the hitch the culprit? Even though it looks OK.
  • Wow
Reactions: ccw
MODs to date
When I installed and ran the wiring for the supplemental rear lighting I had a similar situation. The timing was very coincidental but ended up being something else nowhere near the work I had done. I went through all my wiring just to be sure prior to taking it into the dealer. Ended up being a pinched wiring loom that must have finally shifted and shorted out a circuit, taking out my interior lights, garage door opener, mirror lights, etc.
Sooo….it was me that created the problem. In my initial post I noted that I checked, double and triple checked the connector on the hitch where the DRW running lights tap into. That is where the problem was found.
In the video that shows how and where to wire the Limitless harness into the connector on the right side of the hitch. They instruct you to “break” the plastic door using a thin punch and then push the pin into the door you opened. Apparently I used too big of a punch (I used a test light). Although I got the pin in the correct slot and made the connection; my heavy handed ham fist managed to spread the connector next to it out of shape; apparently it is the power for the BLIS and Cross Traffic sensors. When the connector was plugged back in, the BLIS power pin was not making contact.
So there ya go! When the fellow in the video says make sure the pins a lined up where they’re supposed to be, ALSO make sure they are all the same size.
Problem solved; wallet sore!
When you say wallet sore, meaning you took this in for service and they found it? You explained what the issue was but didnt say how you finally discovered the issue.
I finally had to go to the dealer. I just told them the BLIS and Cross Traffic faults were on. About an hour after they opened this morning my service advisor called and said the BLIS sensors (L&R) weren’t getting power. They’d have to trace the harnesses and Oh by the way….we noticed the utility lights (DRW LED assembly) tapped into the same connector. If that is the cause, it won’t be under warranty.
The bill was for the diagnostic fee and two hours of labor. No parts needed; they just reshaped the connector.
Well at least the issue is resolved. I too had a hard time installing the DRW light but mainly because i had 2 connectors where instructions called for one. Slowly i traced and figured out what the deal was with the second connector. When you’re doing these mods the first time without experience it can sometimes go the wrong way.
It's too bad my DRW module and harness kit wasn't available at the time you installed yours, as you wouldn't have had to deal with these issues and messing with connectors and factory pins. So sorry this happened to you.
