Best LED bulb upgrade for halogen headlights
Disagree completely. The LED bulb upgrade is a huge improvement on the stock halogens and well worth the few hundred bucks it costs and hour they take to install.
Major safety improvement for the expense.
Had the f150leds.com bulbs had to remove them way to bright I was blinding upcoming traffic. Trust me a huge improvement from stock.
Well now I think I will just give the XB Hybrids a shot, these seem the best bang for buck right now, if I can just find some that is..
I am so gonna be broke by the time I do all I want to this damn truck. heh
I "had" the f150led led bulbs. The left side (2) went to flickering! After buying $40 slyvanoa bulbs so I could finish my 8 hr drive home I found that there was corrosion in the sockets. The sockets have no rubber gasket like a good weather-pak does
I never got flashed. Took a little bit to get them adjusted
I'll try another vendor. As my backup lights I got from F150. One side has moisture in the housing!
Ugh. I'm in this dilemma too. I just got two different pairs of LED bulbs from Amazon for about $37/pair. One was Sealight.
I'm in a nanny state where I have to take the truck in for inspection every year. I ordered the bulbs before I knew what exactly was involved in swapping them. An hour once isn't a bad deal but I doubt I want to do this twice a year to swap, inspect, swap back. At the same time there's no way I'm spending $1500 on new housings.
The lifespan of Silverstars are about 6-9mo in my experience, so that isn't a solution either. OEM piss yellow it is...
I broke down and spent the $$$ to buy the S-V.4 LED bulbs at headlight revolution. Easily 2-3 times brighter than the halogens and I never get flashed by on coming traffic.
For the fogs, I'm running the Diode Dynamics SS4 lights.
Love this combo and completely eliminated my regret for not getting the factory LEDs.
How are the S-V4 LED lights? Seriously considering these as well. Don't mind spending the extra $$$ for quality if still have true low/high unlike the others have stated about the F150LED,
I ended up returning my SV4 lights and went with the Morimoto XB Hybrids instead, with goin with the Hybrids I was able to get a set of DD SS3 Pro fogs as well and still was under the cost of a set of regular XBs.
Know this is an older thread but just installed F150leds and same issue my low beams are crazy bright and high beams seem like they should be the low beams. Guess my low beams being that bright are normal? Only driven in the dark one time since I installed the bulbs and the lows are very bright but afraid they may be too bright for oncoming traffic i drove to work with my high beams on lol.
See my post after yours
Well its been 9 months and I have a bulb flicking burning dim. same "mo" as last time.
I would not suggest F150 at all!
Just as the rest have said, the low been is bright, high is scattered. I bought some "4 bangers" to use as brights in the fog lights.
On the search for better LED driving bulbs again.
Or trade this truck for a newer tremor lariat!
Recently on FTE, the company Auxito came in and did some advertising and testing with Superduty owners and so far I’ve seen nothing but positive reviews from forum members. But I don’t think any of it is long term testing.
Look for my review threads over on FTE of the Auxito bulbs. I reviewed 2 different styles and what I found was each style performed differently on Low & Hi beam.
The distance from the base of the bulb to the center of the LED plays a big part in that. I ended up using one set in the bottom lights for best Low pattern and the other set in the top light for best Hi pattern. It’s a bit of trade off but the overall best combination IMO and much better than the OEM halogen bulbs.
I’ve also got (later) the Diode Dynamics SS3 Pro SAE Fog lights and they knock it out of the park. I can run them in place of the Low beams.
Question: I have a 2022 F250 with stock LED headlights and LED fog lights. Is there any point to upgrading these to aftermarket LED bulbs? Or is the brightness of a new aftermarket bulb not much different than stock LEDs?
