Best Forscan Settings for 2023 Trucks
It’s not the triple ding at start-up because that’s also in the same IPC module 720-01-02 that I reset to factory last night when trying to put the door chime back to stock…
Maybe we should start a new thread to see if anyone else is also having this issue? I’m wondering if it’s a Ford software issue instead of something with Forscan? Mine appears to be intermittent…although it’s 98% not working but every once in a while it will make the sound 🤷🏻‍♂️🤷🏻‍♂️🤷🏻‍♂️
i'll pay closer attention to it today
I just disabled the following:
Seat belts
Triple ding
Door open ding
the nav settings that allow you to type when moving
Black box on rear camera
All of the settings worked
Seat belts
Triple ding
Door open ding
Are there any side affects to enabling Nav in motion?
37" Tires and adjusting for the speedo. Does anyone have best practices for getting it close AND getting rid of the P160A error code.
With my 37" BFG Mud Terrains, I need to be at 2828mm circumference, and I get the following message in ForScan when I try to relearn the PCM: tire circumference: parameter in central configuration is out of range for this module. Were you able to get around that using a smaller mm circumference or did you figure out another work-around?
On both my Tremors, the max I could set it to was 2782mm for it to work, unfortunately. Some folks have been able to get 2792 to work, so they say, but I am not sure I buy that.
