I would definitely not run Evan’s in my truck. It’s fine in some applications, but not road vehicles or race bikes. DAMHIK!Evans Waterless Coolant for our trucks, their coolant is $57.95 a gallon.![]()
@The Evil Twin : That's the .PDF!! Big bonus points there so people can read the way Ford outlined the coolants.
@AZsurveyor : Yea...I hear you Brother. Worst thing ever to happen we trust people to do it right, which for some reason they just can't. UUggghhhhhhh. Only to spend more money to get it right, or forcing you to "trust another" one more time.
I bring this point to the front :
Flushing:
• Flushing the cooling system is not required prior to entirely replacing (draining and
refilling) Motorcraft® Orange Antifreeze/Coolant or Motorcraft® Specialty Green Engine
Coolant with Bittering Agent with Motorcraft® Yellow Antifreeze/Coolant if the cooling
system is not contaminated.
By the example at worst this is every 50,000 miles??? Trust me I wish it was a super easy $25 fix...but it's going to be a bit more squeeze.
I read that Flushing as saying you can drain and top off the system. So maybe just grab a few gallons, pull the drain, top off. Do this a few times over and not worry. Or just get it right...I know.....more money to fix a problem that should have never popped up.
@Apples : I'd have to check myself but the PSD secondary coolant is functioning to the fuel and Charge Air Cooler for the 6.7L motor. I'm thinking for the Godzilla....might not be a thing. Looking over my 2022 Owner's Manual the G-Zilla uses the same spec'd coolant, only running one coolant system.
I know we went through that possible choice with the 6.0L diesel finding NO ONE who had the knowledge recommended use for that diesel motor. Maybe it's changed?? I'm not taking that chance myself.
