Best AT tire for towing?
Nice looking tires. But I doubt they’d be that great on wet weather, especially snow.
Reading that wet traction is good, towing performance is impressive (load range E), only downside I'm reading about is road noise. Might try these when the Duratracs wear out. I also do a considerable amount of towing, but can't stand the idea of a highway tire on this Tremor.
Reading that wet traction is good, towing performance is impressive (load range F), only downside I'm reading about is road noise. Might try these when the Duratracs wear out. I also do a considerable amount of towing, but can't stand the idea of a highway tire on this Tremor.
Where do you see load range F? BFG web site says 4080 lbs at 80psi (129Q) That sounds like load range E to me. They look like a nice tire for the dry and not too crazy mud, but with so little siping, I can't see great wet performance and Snow performance is probably poor. I am guessing that they will last very well with a heavy load.
Agreed. Almost zero siping and we know with the other ratings they carry, they aren’t constructed with the flexible rubber compound that other winter type tires are so while they may shed rain water a bit, I bet they’d be pretty slick on snow & ice.
I went with the Baja Boss in a 305/70r18 on stock rims.
I thought the stock duratracs were pretty good for the first half but then they got noisy and significantly worse in the snow. The new duratrac RT looks like it has the 3 peak symbol again. Different compound and siping. Looks pretty good too.
Snow traction was important for me as well as towing. Most of my offroad is (lame) gravel roads or muddy jobsites so nothing any AT tire couldn't do really.
Tow a 14k dump trailer and other trailers and they feel stable. Mileage went down by @1mpg.
Not noisy for how aggressive they are. Took a lot of weight to balance.
They are heavy but built tough like the BFG KO2, at least the carcass. I think they look really good.
I would definitely look at the yoko ATG015 for more on-road focus. Probably really good all around and mileage but the looks are just meh. Pricing is good also. Comes in a stock 285/75r18 and a 35/12.5r18.
Falken AT4 would be another good choice. So many tires, so many decisions!
You're correct, my mistake. Load Range E.
