Bed cover… Help spend my money
OK...
For you Revolver X4S owners. Does this seem flimsy? The videos online make it seem like it'll have a short life.
Can I fit a motorcycle in the bed still?
Can it be easily removed?
Seem to be sturdy and secure?
At this point, I'm between RollnLock retractable and the X4S.
I've called this out before on the forum, but I'll call it out again for the Peragon specifically.
With the cover open, if you have anything at the front of the bed you cannot close the cover. There needs to be a certain amount of space between the cover and your cargo for it to close. This means you cannot fully load the bed and expect to close the cover after the fact.
With the cover closed, if anything slides to the front of the bed while driving you will not be able to open the cover.
Both of these are due to the way it opens/closes. When opening/closing it takes up more than the space it takes when stowed, and there's nothing preventing an object from entering that space.
That factor was an immediate deal-breaker for me when I was considering covers. How much that matters to each person will vary, of course.
OK...
I thought the Revolver had to be unbolted to be removed but could be mistaken. The Truxedo Sentry (or Sentry CT) can be removed quickly without tools and has a similar hard rolling design. One of the reasons I am leaning towards that one since I often fully remove my current cover.
OK...
I wouldn't necessarily call it flimsy, however, you have soft vinyl covering aluminum slats. So anything that is soft is going to lose durability for the gain you receive in functionality, in this instance, not losing bed space to a canister and not losing visibility out your back window when the cover is open.
Can a motorcycle fit in the bed? Yes. Depending on how large your front fender of the wheel is. I'm not sure what motorcycle you have, but my dirt bike (Kawasaki KLX300R) fits in the back with my Retrax cover (with canister) with plenty of room to spare.
Look at things this way:
Hard Folding Cover (ie. Bak MX4)
Pro: Security, ease of use, durable powder coated aluminum finish
Con: Blocks rear window when open all the way
Retractable Cover (ie. Retrax/RollNLock)
Pro: High Security, ease of use, durable finish, no loss of visibility when open
Con: You lose roughly 11x11 of bed space due to the canister
Rolling Cover (ie. Revolver X4)
Pro: Ease of use, no loss of visibility when open
Con: Less security, soft vinyl can lead to lower longevity over the years
There is no perfect cover. On my Raptors, I always run an MX4 because I don't want to lose the bed space with a 5.5' bed. On my Super Duty, I run a retractable because I don't mind the loss of space with the canister because of the 6.75' bed. Personally, I won't run an X4S as that's the cover I have the most issues with. Some folks love them, some hate them. We continue to sell them because they are a good brand and Bak backs them up with a solid warranty. But being around them enough, they're not my cup of tea.
I have the bakflip MX4. Works well most of the time… or at least till I need to open and close it. half the time it doesn’t shut flush against the bed. The L shape weatherstripping gets hung up on the joints between panels. Usually have to get up in the bed and help it go down flush. Needing to add some gorilla glue to keep the weatherstrip pieces in place on that joint.
Also the pecans have added some hail damage type dents. Haven’t experienced either of these issues with roll n lock on the f150 trucks at work.
The MX4 is alright. But Knowing what I know today I would consider roll n lock or maybe Diamond back.
I've had this happen when it's cold. I was able to pop it back in with some effort. I was planning to give it some WD-40, that way it will slide in the channel better - maybe even some other grease if needed. However, it has only happened once.
My 2 cents...
I don't think the X4S is any less secure than any other of the covers being discussed. Illegal entry would be handled the same way by prying up.
The X4S I received, has hand knobs instead of nuts to totally remove the cover.
Pretty much anything that would fit in a bed with no cover will fit in a bed with a rolled up X4S.
I think the X4s has the cleanest look.
If you want to make it a little harder for thieves and also risk more damage to your bed then perhaps the Diamondback or Renegade would slow (maybe??? deter).
If a thief want something locked in a console safe in a locked truck, they will get it.
I have had soft rollup covers on my previous trucks and never had a problem. I got the X4s for better looks and functionality and maybe deter the casual thief from looking in my bed. If I had a bigger worry about theft, I think I would relocate to a different location.
I have the Roll-N-Lock E-Series
on my 2017 & have one waiting to install on my 2022 tremor that is at the dealership waiting on me to pick up. I have had it on my 2017 since about 2018 & it has worked great.
I tried to see if I had any pictures of it, but this is the best that I have...
As you can see the "storage" part of the box comes down about even with the hook on the side.
There are times that I wised that it was not installed, but they are fewer than the times that I am glad it is there.
Thanks for this info @Mako - similar to what I have on my soft tri-fold for removal... This places that "function" on par with the Truxedo Sentry line in my opinion then.
I've been looking into getting a cover. Looked enough that I think I might be cross-eyed now! :ROFLMAO: I started off looking at "cheap covers". But all of them close on the sides with Velcro. Which I don't want. My last cover was a soft snap down that worked fine but sucked when opening and closing. I'm really leaning towards the BAK Rev X4s. Especially now that @Mako says it has hand knobs and not nuts for easier removal.
Definitely a great product! We have a lot of guys who buy the Revolver x4s and swear by the product. Shoot me a PM if you are interested in looking at some pricing and I'll see what kind of forum price I can get you.
