Bringing this one back but if buying a used fiberglass camper and warranty isnt a concern, has anyone looked at using a dremel/router to cut a portal into the front of the shell where the bed lights and camera are (like the RSI) and adding a grommet seal and poly window there for visibility? Tap plastics can cut to the size you need or just set up a jig and router the panel yourself.
Thinking outside the box but seems like it might be doable if that area is flat for 3rd brake light clearance.
