Great explanation
@Himni. That the dual battery can be installed and wired independent of a second alternator was the missing piece of the puzzle in my head. Always thought the dual battery was tied to a dual alternators and that the two 12v systems were separate, isolated and independent. Your explanation clears that up.
@StrokinOut Too early for window sticker as of yet. When I click on the View Window Sticker button when logged into the Vehicle Tracking site, it says "Check back later. Window sticker has not yet been release for this vehicle".
Looking through my build sheet from my dealership, I do have the Pro Power onboard options, the Warn Winch option and the $210 dual battery option.
Interestingly, the Ford Build site lists the following info:
Pro Power Onboard $985: Requires dual battery. Includes dual alternators (12v 250 amp and 24v 150amp)
Warn Winch: Requires 410 amp dual alternators (250amp + 160amp) and 4x4 on gas engines. Dual battery on 7.3L.
Dual battery option: Requires 410amp dual alternators (250amp + 160amp) or Pro Power Onboard 2kW.
Since the pro power onboard includes a 24v alternator, that alternator can not be tied into the 12v batteries of dual battery option. But maybe they make an exception, if pro power is optioned, that the dual battery does NOT require dual 12v alternators like their specs say it does. When one has dual batteries and dual alternators optioned, then attempt to add pro power onboard, it stipulates that two items must be removed; 410amp dual alternators and 120v/400watt outlets. So I guess they are satisfied that the single 12v 250amp alternator, that is included with the pro power onboard upgrade, is satisfactory to run the dual 12v batteries and winch. But then why require those that get dual batteries or the warn winch, but NOT the pro power onboard, to pay to upgrade to 410amp dual alternators if the 250amp is satisfactory? Perhaps it's just a matter of what is satisfactory and what is best.
This also means a total of four batteries for pickups with dual 12v battery option and the pro power onboard option.
In any case, the pro power onboard system would have been much simpler if they did not do a 24v alternator and little 7.5amp dual AGMs wired in series under the rear seat and, presumably, a 24v inverter. They could have easily done two 12v alternators, two 12v batteries and one 12v inverter for pro power onboard. Seems they overcomplicated it, but perhaps that was to prevent owners from overloading the 12v system by trying to use pro power onboard, winch, etc. all at the same time. Save us from ourselves! Ha.
As mentioned, had I known how they overcomplicated the simple act of adding an inverter, I would have not opted for the pro power onboard. I would have done 410amp dual alternators (250amp + 160amp) and dual 12v batteries, then wired and installed my own 12v inverter under the seat. That would have eliminated the need for the two extra little batteries that will wear out and need replaced, add weight, take up space, etc.
