Banks iDash A-Pillar Dual Pod Mount Not Compatible w/Platinum Plus Interior
Did you get a solution? I missed the caveat about it not fitting a removable handle. Just came in today and tried to install, and now see it won’t work with the Plat+.
I am working on a solution that will work as a very good “temporary” install. I will finalize this weekend and do a write up. I have not had any response from any of the groups I have reached out to for a custom solution.
High level: I am using the Banks Performance Dual Pod (suction cup) and pairing it with the 23+ Edge CTS3 Custom Mount. Both of these utilize a 17mm ball so they fit together. I mounted it up last night and it seems to be sturdy. Now I’m attempting to route the cables cleanly, which I believe will be achieve by removing the lower A pillar handle bolt cover, drilling a hole to route the cables, and then using a rubber grommet to cleanly route the cables to the pod (less than 2” of cable exposed). This is going to come in around $120, same price as the solution from Banks (which does not work for Plat+).
Here are the install guides which show the exploded of the brackets:
Banks Dual Pod Suction Cup Install Instructions
Edge CTS3 Install Instructions
My hope is that someone comes up with a more permanent solution, but what I have will serve my needs (with little modification) until that comes out.
Researching, I did find where you can purchase the Ford Light Smoked Truffle Removable Interior Handle for the Plat+ interior. I wanted to know how much it is going to set me back if I mess up my drilling.
Here is the official Ford Site for $423.22.Yes, that is just for the removable handle.
Here is an online site that has it 32% off.
Thanks for posting this. I’m going to do the same thing. Really appreciate it!
No problem. I am going to work on wiring tomorrow. Here are a few shots of what it looks like installed without the idash units. It could go horizontal as well, but after playing with the options I liked it vertical. I also prefer the placement to not obscure any view through the glass.
I installed the dual iDash units and PedalMonster today. My original plan was to modify the lower A-pillar grab handle mounting bolt and route the cables through a grommet. However, between the dual iDash units and the PedalMonster, there are three cables that need to be routed, which would have been too many to cleanly pass through that location.
For now, I opted for a temporary cable run tucked just under the A-pillar so I could confirm everything was working properly while I reconsider longer-term mounting and routing options. I used wire wrap to keep things reasonably tidy in the interim.
I’m completely sold on the dual-screen setup. Banks provides a lot of flexibility in how you view and configure truck data, and the overall level of insight is impressive.
I have dual screen too and love the data Banks provides.
