Baja Lights Question
Everything is installed correctly. Fog light switch turns on the SAE lights only. Aux switch turns on all 4 lights. The anti-back feed harness's purpose is to not allow power to be sent back into the factory fog light wiring when you flip the upfitter.
If you want the AUX switch to only turn on the Squadron Pros, remove the anti-feed harness and the small 2-way splitter. Plug the 55" harness into the Squadron Pro on each side of the truck and then plug into the upfitter harness and make the connection at upfitter and the 2 pairs of lights will work completely independently of one another.
Thanks Nick. I'm actually glad all 4 lights turn on with the upfitter. I just wanted to make sure it was wired correctly which it is. Less than 15amps for all 4 which is nice.
Question on the amber kit. Is the color of the amber close to OEM (orange) or yellow (amber)? The pic showing them installed shows a more orange color but the parts breakout pic shows a yellowish color.
It's light output is closer to yellow.
The output on the yellow SAE lights is 3000K so it is a true yellow light. It doesn't aesthetically match the factory amber, but is a much more useful color temperature than the OEM amber for actual light output.
We do have both the yellow SAE and white SAE kits in stock with Squadron Pros along with XL-Linkable kits if you're in the market. No lead times here!
