Baja Designs S2 Backup lights - Simple Mount
Or, you can use heat-shrink tubing for electrical and shrink it around the hose clamp. I've done that with my fire extinguisher mount and it is much cleaner looking than stainless since the extinguisher and the mount are both black.
That's the easy button, right there. I was thinking 3/8" fuel line, but heatshrink is even better. Thanks for the idea!
I just got a set of the S2 for the back of my truck, and I have the OEM step as well, so this helps me think of other ways to attach them and not lose use of the step. Im leaning square u-bolts , but assume the 3" will not fit needing a tad more space. If anyone else has ideas similar to this without drilling please share.
Well I can confirm that a standard 3 x 4 square ubolt from Ace Hardware will not fit on the hitch for this. So not sure if you can get like a custom sized one that is slightly bigger, as I feel if its a 3.5 or 4 inch it will be too wide. Not sure which way I want to go with installing these lights now. I still would prefer to put them in this same location, I just cant think of another method to bolt\strap them on there.
I’ve got this as a temp set-up for now to keep from having to drill into the hitch, but seems to be holding up just fine. I don’t have the step so not sure if this would still be in the way.
I agree the flush mount is the best looking, no doubt...but I just dont have it in me to try to cut those holes and try that...I also dont want to drill into it either, so I am choosing the hard path of finding a way to attach it instead.
Agreed. No way would I drill holes in the hitch or cut permanent hole in bumper for flush mount (tho it does look the best). I keep trucks for 10-20 years and my light of choice will change over time and the mounting method needs to be able to adapt to those changes IMO.
So, I grabbed the digital calipers and went out to measure the hitch tube. OD of the hitch tube seems to vary between 3-1/64" and 3-1/16" depending on where I measure.
McMaster-Carr has some 3-1/8" square u-bolts so I think that will be my approach. Use some rubber to pad it out as necessary.
square-u-bolts
3060T271
I just went ahead and cut holes in the bumper and installed flush mounted. Wired up to an upfitter switch and they really light things up back there!
Perfect, i believe this is a perfect spot for these lights on a SD. I saw one in person and it looked just right. I dont get why many on the forum are hesitant “to cut into the bumper” for these lights like its some kind of sin.
Not BD lights, but I installed these last night. Wired to Upfitter switch so I can use them only when I want, don't like them tied into Reverse. Made a homemade bracket so I could have the lights level instead of following the angle of the bumper. Had these same lights on my previous truck and they've been good lights for the price.
https://www.amazon.com/dp/B081DTRC46?psc=1&ref=ppx_yo2ov_dt_b_product_details
I just ordered some of these. Was hoping to see some install instructions, hopefully will be some in the box. They may show up before I get the truck though.
Straight forward. If you email kurt via the website, he'll send them to you.
Behind the bumper, there are two bolts that will line up with the holes....super simple.
Do you know if those will work with the bed step ? This is what sorta started this whole thing...the step being in the way for most standard installs....I ended up trying ubolts, didnt work...not way to tighten it up enough, it was just bending the back plate and never held it tight enough...so went to the hose clamp, painted them matte black and worked like a champ...but if these mounts work with the step Id consider changing them to these.
So, I have the S2s on the way from Nick. Been thinking about this. Have some 1/8" aluminum in the garage. Thinking about making some longer plates that use the same bolts as BD but extends inwards to clear the step. It would basically cantilever the lights out. Have to see if that would work.
i got my baja designs back up lights hooked up. i ran them to upfitter number 6 always hot. no key needed. thanks for the awesome idea starwhite.
here is a look at my raptor lights also. not exactly raptor lights but close enough. i can't have to many lights. i love lights.
Can anyone provide a dimensional sketch of the BD S2 reverse light mounting brackets? I'd like to fab them myself.
My S2 reverse light kit did not come with the brackets.
Finally got around to installing my Baja Designs S2s for backup lights. I really struggled with the low light of the factory backups - tasks like hooking up my boat or even backing into my driveway left me struggling to see clearly.
Instead of the usual Baja Designs bracket, I used 4" stainless steel hose clamps and attached them to the receiver hitch crossmember. I probably could have painted them or found coated hose clamps, but for my use - they are totally fine. The distance is just right, they are pretty protected, and they work great at night.
Hope this might help someone else.
Also, forgive the dirty Tremor - it's been a monster year of snow/dirt/crap weather and it's way overdue for a good handwash soon.
Ins
I did the same thing! I tried drilling into the hitch with a DeWalt hammerdrill and a new carbide bit and after 10 minutes I only scratched it :)-- . I did one thing differently, however. I put a piece of 1/2 x 2 on the back side of the hitch so the ring clamp would get some "crush" tension. I couldn't get enough tension on the hitch alone without stripping the little gear.
