B&O corner dash speaker adapters and speaker wire plug and play adapters.
Digger29
Oxford, Ma
2024 F-250 Tremor
2020 Jeep Rubicon Recon Edition
I got all 4 doors done today and damn it took pretty much all day with the adapter plates, block off plates and tons of sound deadening material. I went to do the corner dash 3.5's and the pillar tweeters and ran into a few issues and now I'm stumped, and I gave up for the day. I went with the Focal Flax 3 ways and MTI sent the speaker adapters for the 3.5's and the tweeters. Has anyone done this yet with the Focal stuff that requires the adapters? Also does anyone know if there's a plug & plug speaker wire adapter for the 3.5's because I don't want to cut the plug and solder the new plugs on. There's like zero room up to be soldering anything. Also, what's trick with the speaker adapter for the 3.5's? The adapter for the tweeters will probably work but it looks like I might to hot glue gun the tweeters into the MTI brackets and then they'd appear to be sitting further back in the pillar than I expected using the MTI adapters. This is my first and last attempt doing this kind of stuff because I got my ass kicked today and I'm not nearly done. Thx guys!
Interesting. In my 20+ years of doing car audio ( hobby / novice) I always ran new speaker wire when replacing speakers
There's no need in running new wires. I only need or have to run new wires from the amp to the tweeters.
