Also worth having them check and replace the steering wheel volume control buttons.
Just got my truck back from being at the dealership for two weeks for the exact same issue. They replaced the ACM and the digital processor with no luck. They can’t get anyone at Ford to help. What ended up being the solution for you?so frustrated. the dealer worked on mine for about 10 days and still cannot figure it out. i.am told they tried to work with ford tech online but ford tech server has been down for 2 days. it is really frustrated and rediculus.
Did you ever get this issue fixed? So frustrated that my local dealer can’t figure it out. Everything works, but volume is stuck on 0.What you describe in the other post are not my symptoms. Mine works 100% just the volume gets messed up.
I would try the easy things first, if nothing else than to rule them out:Did you ever get this issue fixed? So frustrated that my local dealer can’t figure it out. Everything works, but volume is stuck on 0.
Unfortunately I have done both and so has the dealer. I picked it up today after it sat there for 2 weeks while they waited on the Ford help desk to respond. Just trying to see if anyone got it resolved.I would try the easy things first, if nothing else than to rule them out:
1) Pull radio fuse (suggested by several in the above merged thread)
2) Sync reset - hold volume and right arrow/seek button simultaneously (also suggested above)
Did you get the issue fixed? I’m having the same problem on 2022 f350 and I’ve tried everything. Replaced fuse 28, unplugged the amp and plugged it back in, left the batteries disconnected for 4 hours, hard reset and soft reset the sync screen. Nothing is workingDid you ever get this issue fixed? So frustrated that my local dealer can’t figure it out. Everything works, but volume is stuck on 0.
