- Uneven trimming of fiberglass at rear door was about 3/4" different, leaving a big gap on one side.
- Door was either too long or misaligned on one side, meaning the flap that covers the top/back of the tailgate touched the paint on the aluminum and would wear through the paint.
- Rear door frame was bent at the end.
- Cap seemed too long, allowing water to get in at back of bottom rail (presumably).
- Gap in the ceiling carpet about 1/4" wide at the seam.
- Most/all window screws way over-driven, bending the window frame extrusions (installers said every cap comes this way - I'm curious if it'll be correct on the cap when it comes back).
- Overlapping aluminum trim on inside of window frame (rather than true butt joint). Snag/cut hazard.
- Numerous areas with frayed screen material coming out of the window frame.
- Bottom flange that sits down inside the bed rail was something like 3/4" longer on one side than the other.
- Seal for fold-down window was too long but crammed in, meaning it didn't sit tight against the aluminum frame (bunched up instead).
I'd also pay close attention to:
- Paint (chips, runs, swirls, etc)
- Overall fitment and placement (gaps, etc.)
- Function (windows, lights, locks, etc.)
- Any obvious seal issues (aluminum trim not tight against the fiberglass, etc.)
